Memphis 16-mcd1000.1
I working on a Memphis for someone and one of the safety caps is completely burnt up and I need the value. C240.
both driver cards are the same in either side the output remains the same. a high pitched sqeal emittits overtop the audio. regulated voltage is good no opamps seems to be heating up. One of the 33uF 200 NP caps seem to be getting hotter than the other. there is
-0.055vdc at the speaker terminal
Yes perry the cap was making a sizzling scary type noise so I pulled them again. And now they are failed, they were also damaged badly at the initial year down but tested within tolerance so I reused them until I could find replacements. I am having a difficult time finding non-polar 33uF 200v replacements.
Compare the readings in the board with the filter caps out of the circuit. If you remove them, you may break any intermittent short and they may appear to be OK.
You can also install the filter caps with a current limiting resistor in series with one terminal of the cap and compare the voltage across the limiter, one side to the other to see if they're the same.
