DD Z2B Stuck in protect
Old 24th July 2019, 02:26 AM   #51
Perry Babin is offline Perry Babin  United States
Look at the internal diagram of the IC and it shows a pullup resistor to an internal 5v supply.
The J111 (if that's what it is) pulls the voltage on the SD pin down to the negative rail initially but when the power supply powers up, a negative-rectifying diode charges a capacitor negatively and when the negative voltage reaches a threshold, the voltage on the SD pin is released and it rises to the voltage that it's pulled to internally.
On that same 'type 3' page, you also saw that the 21844 has a threshold of about 2.1v so I'd expect that the voltage is OK but if it's not pulling up far enough (no j111 in the circuit), I'd expect that the IC was defective (even if new).
Some ICs need a high to shutdown but most that have an overline on the SD shut down when the pin is pulled low.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 24th July 2019, 02:35 AM   #52
netace is offline netace  Canada
Thanks for the clarification Perry
Old 26th July 2019, 12:00 AM   #53
Bills amps is offline Bills amps  United States
ill change the IC again. and recheck. Thanks Perry.
Old 26th July 2019, 12:01 AM   #54
Thanks netace
Old 26th July 2019, 12:43 AM   #55
Changed the IC. still 3.8v on SD pin.
Old 26th July 2019, 12:49 AM   #56
Is this with the j111 out of the circuit?
What else on the driver or main board could be keeping it down?
The 3.8v shouldn't prevent the IC from producing output but it's strange that it's not going to 5v
Old 26th July 2019, 01:19 AM   #57
I pulled the j111 and still has the 3.8v on SD. Also checked pin 5 and has 12.2v.
Old 26th July 2019, 02:21 AM   #58
Desolder and lift the SD terminal of the 2184. Does the voltage on that pin go to 5v?
Did the ICs come from a reputable distributor?
Old 4th August 2019, 04:54 PM   #59
was thinking of doing that or using a separate power supply to inject 5v at the sd pin.
And the parts always come for mouser.com
Old 4th August 2019, 05:23 PM   #60
Be careful if you inject voltage. This is referenced to the negative rail and your source of voltage has to be floating (with respect to all other grounds/supplies) so you can connect it to the negative rail safely.
DD Z2B Stuck in protectHide this!Advertise here!
Anthem MRX 300 av receiver stuck in protect. Need help. TommyVinegar Solid State 7 12th March 2019 02:45 PM
monoblock amp stuck in protect... mixalos spl Car Audio 23 31st January 2017 08:26 AM
300/2 Stuck in Protect jlind54 Car Audio 15 26th July 2014 05:37 PM
Samson Servo 550 stuck in protect...help! freestuffrocks Solid State 0 7th April 2012 07:18 AM
TL494 stuck in protect Clipped Car Audio 13 4th March 2008 04:45 AM
Copyright ©1999-2019 diyAudio
