DD Z2B Stuck in protect
Old 6th July 2019, 02:52 AM   #21
Bills amps is offline Bills amps  United States
Okay back to this thing. I have pulled the outputs out again. Replaced the IR2184 and still no drive on the gates Low or high side. But it is not in protect. All four of the fets that i had installed are all still good(one per Bank).
Old 6th July 2019, 08:40 AM   #22
Bertje is offline Bertje  Netherlands
I had a missing +12V from L7812 (connected to the TC4452 drivers) and output from IR2184 is ok?
www.12vhifi.nl all about car audio & Hybrid Audio Technologies Netherlands & Belgium
Old 6th July 2019, 10:31 AM   #23
Perry Babin is offline Perry Babin  United States
Do you have drive signal reaching the IC?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 7th July 2019, 04:50 PM   #24
I will check for the 12v. And i dont have any drive from the driver board. I changed the Ir2184 ic.
Old 7th July 2019, 04:54 PM   #25
Do you have drive reaching the input to the IC?
Old 7th July 2019, 05:27 PM   #26
Not sure what you are asking? I am not sending any audio at the moment if that is the question.
Should I? Does it take some audio to turn on the drive wave?
Old 7th July 2019, 05:32 PM   #27
If the amp won't oscillate, it could be that it requires a bit of signal to get it started, then it will oscillate at normal operating frequency (assuming that the circuit is complete, outputs in the amp, etc). If it still refuses to oscillate or if the amp circuit is incomplete, the input will allow you to test some parts of the circuit.
Old 7th July 2019, 06:48 PM   #28
I put the fets back in. One per bank and the amps goes back into protect.
Old 7th July 2019, 06:50 PM   #29
I am missing something somewhere. Frustrated....
Old 7th July 2019, 06:59 PM   #30
It's generally best to confirm that you have good drive to the outputs before you install them. The exception is for amps that will produce drive with no rail voltage. Then you remove the rectifiers.
I'd suggest that you remove the outputs and get signal to them before testing with the outputs in the circuit.
DD Z2B Stuck in protectHide this!Advertise here!
Anthem MRX 300 av receiver stuck in protect. Need help. TommyVinegar Solid State 7 12th March 2019 02:45 PM
monoblock amp stuck in protect... mixalos spl Car Audio 23 31st January 2017 08:26 AM
300/2 Stuck in Protect jlind54 Car Audio 15 26th July 2014 05:37 PM
Samson Servo 550 stuck in protect...help! freestuffrocks Solid State 0 7th April 2012 07:18 AM
TL494 stuck in protect Clipped Car Audio 13 4th March 2008 04:45 AM
Copyright ©1999-2019 diyAudio
