Orion HCCA 2100 no rail voltage.
Old 3rd May 2019, 07:20 AM   #281
Chopperbuilder is offline Chopperbuilder  United States
Thanks for the info Perry.
Multimeter: Blue Point - Model: MT586B / Oscilloscope: Leader - Model: LBO-524 / Power Supply: Modified computer 500 watt
Old 5th May 2019, 04:08 AM   #282
Perry, I'm not sure if you seen my question in post #250 about your recommendations on what 10uf 50v capacitors to use in these amps...actually my question also applies to all of the old school Orion amps?
I've been using Nichicon UHE1H100MDD1T. Yes, those are the capacitors that I had two of fail in this amp. Mouser, who I bought them from, replaced my entire order of 100 after I told them about those two failing as they did.
While UHE1H100MDD1T has seemly been working well in most of circuity where a 10uf 50v capacitor is needed, it is not working well in the muting circuit. I just finished repairing and recapping an XTR 2250 and used a UHE1H100MDD1T in the muting circuit. The muting circuit would function as it is supposed to for few minutes then the negative DC voltage on the third leg of the muting transistor would start rising and pulsing. After checking a number of other components in that circuit I pulled the UHE1H100MDD1T and replaced it with a different brand of 10uf 50v capacitor and the circuit works as it should. I then pulled that capacitor and I tried another of the UHE1H100MDD1T's it did the exact same thing the first one did. After that I put the other brand back in and again the circuit functions as it should. I'm thinking the resistance of the UHE1H100MDD1T is too low to function properly in the muting circuit. That is what lead me to asking you again about your recommendation of which brand an model 10uf 50v caps to use. Also would it be better to use a different model capacitor in all the 10uf 50v locations through out the amp?
Old 5th May 2019, 04:35 AM   #283
Perry Babin is offline Perry Babin  United States
The muting circuit uses incredibly high values of resistors and relies on those resistors for the voltage at the muting transistors. If the capacitors have ANY (electrical) leakage, they're likely to cause problems.
I don't have a recommendation, really. The Nichicon caps would likely have worked perfectly well as designed (for filtering/bypassing noise). CDE caps have had a good reputation. If you want something that is almost impossible to fail, use a film capacitor. It won't look the same but it shouldn't have any leakage.
Tantalum capacitors have low leakage and used to be considered unreliable but are OK today.
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 5th May 2019, 05:19 AM   #284
Thank you for the info Perry.
Old 4th June 2019, 06:56 PM   #285
Pulled this amp back off the back burner to work on it again. DC voltage on pin 4 of the 494 is +0.138. Installed a 6k resistor between pin 4 and pin 7 and it brought the voltage down to +0.036v. Found that if I install a 5k resistor or lower between pin 4 and pin 7 the amp won't power up and shuts my power supply down...
Also noted that the amp starts clipping (lighting the clipping indicator lights) at a lower volume than is should be (can be heard through the speakers)...
Any thoughts?
Old 4th June 2019, 07:01 PM   #286
Connecting a resistor of any value between 4 and 7 should cause no problems. In many amps, pins 4 and 7 are directly connected.
What could be happening is that whatever is driving the voltage back to pin 4 is connected to a circuit that's sensitive to the voltage being pulled down.
With the 5k in place, does the voltage on pin 3 of the 494 go below 0v? Place the black probe on pin 7 to test. It's critical that you use pin 7 for this test.
Old 4th June 2019, 08:28 PM   #287
As I mentioned with a 5k resistor in place it shut my power supply down. Should I install the 5k and try running it with a limiter to do the test?
Old 5th June 2019, 03:19 AM   #288
jkrokenberger is offline jkrokenberger  United States
I had issue with an Orion made amp that did not like less than 0V050 on pin 4. Does the HCCA 2100 use dead-time control to regulate the power supply at all?
Old 5th June 2019, 03:25 AM   #289
Powering the amp through a limiter... 5k resistor installed...the voltage on pin 3 of the 494 is +0.047v (black probe on pin 7).
Old 5th June 2019, 03:49 AM   #290
Wasn't the amp OK previously with a 1k ohm resistor and a wire jumper between 4 and 7?
Orion HCCA 2100 no rail voltage.Hide this!Advertise here!
Orion HCCA 2100 fan-what one and where to buy? mclsound Car Audio 6 1st May 2012 12:09 AM
orion 2100 HCCA amplifier trustyrusty10 Power Supplies 3 1st June 2010 01:31 AM
Orion 250 HCCA no rail voltage ECM Car Audio 3 12th March 2010 07:43 AM
orion 2100 hcca mike49504 Car Audio 11 11th February 2008 02:14 PM
Q Orion HCCA 2100 competition amp Leif Car Audio 7 13th October 2006 06:10 AM
Copyright ©1999-2019 diyAudio
