Orion HCCA 2100 no rail voltage.
Old 20th April 2019, 06:42 PM   #231
Chopperbuilder is offline Chopperbuilder  United States
To clarify answer #6: They do not heat up at all with the amp at idle no speaker connected.
Also, the emitter resistor voltage for the 6491's rising above 0.000v is and has been completely intermittent.
Multimeter: Blue Point - Model: MT586B / Oscilloscope: Leader - Model: LBO-524 / Power Supply: Modified computer 500 watt
Old 20th April 2019, 07:27 PM   #232
Perry Babin is offline Perry Babin  United States
That may mean that the excessive DC offset is also intermittent.
Old 20th April 2019, 07:43 PM   #233
I just checked it and you are correct. The excessive DC offset is also intermittent.
Old 20th April 2019, 07:45 PM   #234
Measure the DC voltage on the two inputs and the output pin of the 5534 when excessive DC is present. Also measure when it's not present to give yourself a reference.
Old 21st April 2019, 04:34 AM   #235
I believe I may have found what was causing the intermittent DC offset as well as the voltage to be above 0.000v on the left 6491 emitter resistors. The 10uf 50v cap near the 5534. I again replaced all the 10uf 50v caps on the audio side and the DC offset is now -0.043v on the left channel and +0.065v on the right channel and holding. The 6491 emitter resistors are at 0.000v and holding. The DC voltage on pin 4 of the 494 is still on the high side at +0.165v.
However the output transistors are somewhat heating up. Not just the left side but both sides and they are within a few degrees of each other. Not really driving the amp very hard, after about 4 songs the temp on the heat sink next to the clamp bars is reaching 100 degrees Fahrenheit. Not sure if that is normal for this amp but I haven't found other properly functioning Orion amps warming up that much under the same conditions.
Also the amp is intermittently shutting down. Been trying to determine the cause and the only irregularity I found when it does is the voltage on pin 4 of the 494 is above +4.0v DC.
Old 21st April 2019, 11:56 AM   #236
If this amp has higher rail voltage than the other amps, the outputs will dissipate more heat for any given output level.
Old 21st April 2019, 07:14 PM   #237
Do you think that whatever is causing pin 4 of the 494 to be on the high side is also causing the amp to intermittently shut down and at that point driving the pin 4 voltage up to +4.0v?
Old 21st April 2019, 07:19 PM   #238
Did you try leaving a low value resistor in place 4-7 to see if you could find something that was malfunctioning in some way?
Old 22nd April 2019, 12:59 AM   #239
Can you tell me why there is a capacitor between pins 12 and 7 of the 494 on these amps?
Old 22nd April 2019, 01:02 AM   #240
It filters the incoming voltage.
Orion HCCA 2100 no rail voltage.Hide this!Advertise here!
Orion HCCA 2100 fan-what one and where to buy? mclsound Car Audio 6 1st May 2012 12:09 AM
orion 2100 HCCA amplifier trustyrusty10 Power Supplies 3 1st June 2010 01:31 AM
Orion 250 HCCA no rail voltage ECM Car Audio 3 12th March 2010 07:43 AM
orion 2100 hcca mike49504 Car Audio 11 11th February 2008 02:14 PM
Q Orion HCCA 2100 competition amp Leif Car Audio 7 13th October 2006 06:10 AM
Copyright ©1999-2019 diyAudio
