Orion HCCA 2100 no rail voltage.
Old 15th April 2019, 06:24 AM   #201
Chopperbuilder is offline Chopperbuilder  United States
Yes, it is pulling the supply down to 9.5v. Yes, I am going through the limiter.
I have installed all the parts in the audio section. Amp is out of the sink but fully together with the resistor installed between pins 4 and 9 of the 494.
Multimeter: Blue Point - Model: MT586B / Oscilloscope: Leader - Model: LBO-524 / Power Supply: Modified computer 500 watt
Old 15th April 2019, 06:32 AM   #202
Perry Babin is offline Perry Babin  United States
Are the output transistors on the problem side heating up?
Old 15th April 2019, 06:33 AM   #203
No. The only components heating up are the two voltage regulators on the right side of the board, the same two that have been heating up.
Old 15th April 2019, 06:37 AM   #204
Do you have more than 0.000v across the emitter resistors?
Old 15th April 2019, 06:41 AM   #205
No. The voltage across the emitter resistors is 0.000v.
Old 15th April 2019, 03:53 PM   #206
Are you checking all of the things we covered before, like, do you have the same rail voltage on both channels...
Old 15th April 2019, 07:31 PM   #207
I did check the things we covered before. Rail voltage is the same on both channels (+/-34.195v).
Other than pin 4 of the 494 having high voltage (without the resistor installed), the muting transistors not dropping to where they should be and the odd voltage (rail voltage) on the two A06's I haven't found anything else that seems to be out of specs.
Old 15th April 2019, 07:53 PM   #208
I think this thing needs a priest, not a technician. What does an exorcism go for nowadays?
Pull the two heating regulators. Does it still pull excessive current?
Old 15th April 2019, 08:10 PM   #209
I'm not sure an exorcism costs now days but I'm about ready to start looking into it!
I pulled the two regulators and the DC voltage on the power terminal went up to +10.25v.
Old 15th April 2019, 08:12 PM   #210
What was the voltage before when you thought that everything was OK?
Orion HCCA 2100 no rail voltage.Hide this!Advertise here!
Orion HCCA 2100 fan-what one and where to buy? mclsound Car Audio 6 1st May 2012 12:09 AM
orion 2100 HCCA amplifier trustyrusty10 Power Supplies 3 1st June 2010 01:31 AM
Orion 250 HCCA no rail voltage ECM Car Audio 3 12th March 2010 07:43 AM
orion 2100 hcca mike49504 Car Audio 11 11th February 2008 02:14 PM
Q Orion HCCA 2100 competition amp Leif Car Audio 7 13th October 2006 06:10 AM
Copyright ©1999-2019 diyAudio
