Orion HCCA 2100 no rail voltage.
Old 11th April 2019, 05:38 AM   #181
Chopperbuilder is offline Chopperbuilder  United States
Yes.
Multimeter: Blue Point - Model: MT586B / Oscilloscope: Leader - Model: LBO-524 / Power Supply: Modified computer 500 watt
Old 11th April 2019, 06:04 AM   #182
Perry Babin is offline Perry Babin  United States
Is there voltage on the RCA shield?
All of this and everything I will ask has already been done. Read back through the thread and go through each step.
Old 12th April 2019, 01:41 AM   #183
There is 0v on the RCA shield.
I figured as much and ran through it before hand. What I've found is when the amp is powered up the voltage on pin 4 of the 494 does not drop below +0.310v DC and the DC voltage on leg three of the muting transistors is not dropping to anywhere near what it should be.
When amp power shuts down the DC voltage on pin 4 of the 494 is +3.50v and pins 9 and 10 drop to 0.000v.
Old 12th April 2019, 06:03 AM   #184
Should the two A06's circled in the photo have rail voltage on their collectors?
Old 12th April 2019, 07:54 AM   #185
Someone else may know but I have only the information you've posted for this specific amp. If you can tell me what they're connected to, I may be able to give you an educated guess.
Old 13th April 2019, 05:32 AM   #186
I did my best to draw out the DC current flow to the third leg of the A06 on one side of the board in the attached photo. Voltage starts with the red wire.
The resistor with the red arrow pointing to it does not have 0.000v across it. The DC voltage across it is +0.003v.
Old 13th April 2019, 09:40 AM   #187
Are you sure that the transistor near the red wire is an A06?
Are you sure that the emitter connects to the red wire?
Old 13th April 2019, 05:17 PM   #188
No, the transistor near the red wire is an A56. The transistor near the resistor with the red arrow is an A06.
Yes, the emitter leg of that A56 is connected to the trace that red wire feeds.
Old 13th April 2019, 06:13 PM   #189
I don't think the two A06s near the 494? should have rail voltage. Do they?
There are likely some A06s with negative rail voltage on their emitters but they should be near the emitter resistors.
Old 13th April 2019, 06:25 PM   #190
The two A06's I have circled in the photo in post #186 (one of which is near the 494) both have rail voltage on their collectors.
Orion HCCA 2100 no rail voltage.Hide this!Advertise here!
Orion HCCA 2100 fan-what one and where to buy? mclsound Car Audio 6 1st May 2012 12:09 AM
orion 2100 HCCA amplifier trustyrusty10 Power Supplies 3 1st June 2010 01:31 AM
Orion 250 HCCA no rail voltage ECM Car Audio 3 12th March 2010 07:43 AM
orion 2100 hcca mike49504 Car Audio 11 11th February 2008 02:14 PM
Q Orion HCCA 2100 competition amp Leif Car Audio 7 13th October 2006 06:10 AM
Copyright ©1999-2019 diyAudio
