Audiopipe AP 3000 1D
Old 20th April 2019, 03:37 AM   #71
caraudioguy2100 is offline caraudioguy2100
Here is a picture of the audio driverboard .
Do you know what ic controls the drive signal for the outputs ?
There is something defective on the driverboard which is causing 1 board to have no drive signal to the outputs .
I swapped audio driverboard a and the amp has drive signal on the outputs but this audioboard makes the amp have no drive signal
File Type: jpg B9A2B456-67EC-4F76-AF95-9AD686A69CD9.jpg (1.05 MB, 34 views)
Old 20th April 2019, 06:27 AM   #72
Perry Babin is offline Perry Babin  United States
All of the components have to pass their respective signals. Start by posting the voltage on the header. A marginal voltage there may let one board work where the other won't.
Before pulling the working board, make a note of all pins of all ICs that have the 80kHz square or triangle waveform (no audio input).
Old 1st May 2019, 03:58 AM   #73
Voltage on the header of both boards
Non working board
Pin 1:-4.61
Pin 2:0.00
Pin 3:0.00
Pin 4:-12.97
Pin 5:12.97
Pin 6:0.11
Pin 7:5.00
Pin 8:0.00
Pin 9:5.00
Pin 10:0.21
Pin 11:4.66
Working board
Pin 1:0.00
Pin 2:0.00
Pin 3:0.00
Pin 4:-13.10
Pin 5:12.86
Pin 6:0.11
Pin 7:0.11
Pin 8:0.00
Pin 9:4.99
Pin 10:0.21
Pin 11:0.19
Old 1st May 2019, 04:38 AM   #74
It's likely U704 that's defective.
Old 1st May 2019, 04:43 AM   #75
Do you know what part number U704 is ?
The ones in this amp are defaced
Old 1st May 2019, 05:13 AM   #76
These should be right. You can't trust the build houses nowadays. They've been known to have the wrong numbers printed on the ICs and they look normal.
Old 1st May 2019, 05:20 AM   #77
Thanks for the info I will order the 219 and see what I come up with
Also the small ic is a 4560 correct ?
Old 1st May 2019, 05:41 AM   #78
Yes.
Old 2nd May 2019, 03:50 PM   #79
I’m working on this amp again replacing the lm219.
I noticed that neither board has drive signal on the outputs again .
I ordered new optocouplers .
1 set of optocouplers says
Lite-on high speed optocoupler 10MBd
The other set says
10Mbd open collector high speed optocoupler.
Are these the same pretty much or wondering what one I should use in this amp
Old 2nd May 2019, 07:47 PM   #80
If the optocouplers have the right part number and you purchased them from a reputable distributor (not ebay), either should be OK.
The drive starts with the 4560. Do you have a triangle waveform on pin 1 of that IC on the driver boards?
Audiopipe AP 3000 1DHide this!Advertise here!
Audiopipe AP18001D S Merlington Car Audio 3 12th November 2015 04:05 AM
Audiopipe AP-3002 S Merlington Car Audio 0 4th October 2015 06:09 AM
audiopipe 30001d amp oldschoolamp Car Audio 3 19th July 2015 09:36 PM
Audiopipe APK 2500 S Merlington Car Audio 5 17th March 2015 04:46 AM
Audiopipe ap30001d blazer40 Car Audio 15 4th October 2012 02:27 AM
Copyright ©1999-2019 diyAudio
