Audiopipe AP 3000 1D
Old 16th April 2019, 07:43 PM   #61
Perry Babin is offline Perry Babin  United States
Is that signal on either of the outputs of the LM219 on the driver board, right now?
Are the rectifiers in or out of the circuit?
Old 17th April 2019, 04:10 AM   #62
caraudioguy2100 is offline caraudioguy2100
Rectifiers are in circuit do I need to take them back out for testing
Old 17th April 2019, 07:05 AM   #63
Originally Posted by caraudioguy2100 View Post
The high frequency 80k hertz
Old 17th April 2019, 08:21 AM   #64
No
Old 17th April 2019, 01:31 PM   #65
If you drive a 50-100Hz signal into the amp, how far does that signal make it through the amp? To the outputs? To the driver board?
Testing without the rectifiers is safer. Discharge the rail caps if you're going to remove them.
Old 18th April 2019, 04:24 PM   #66
Went back through the amp replaced the optocouplers
The problem is I get no drive signal on both banks of outputs .
Any ideas where to start checking since both banks of outputs have no drive signal on them
Old 18th April 2019, 04:56 PM   #67
Pull the rectifiers.
Do you get the 80kHz signal back?
If not, drive a strong 50-100Hz signal into the amp and see if the signal (low frequency) returns.
Old 19th April 2019, 12:46 AM   #68
I noticed a bad driver for the outputs .
Is there a sub I can use for the 2N4401 and 4403?
Old 19th April 2019, 12:55 AM   #69
I tried the MMBTA06/56 and the amp wasn't happy. I had to use the originals.
One of these board may have the 4401/3s in the power supply. Something like the A06/56 will work in the power supply so you could swap them to get the drivers if you don't want to wait on ordering them.
Old 20th April 2019, 03:11 AM   #70
After replacing the divers with original part numbers and the 2 optocouplers on 1 board this is the drive signals I get in the high and low side outputs
Do these drive signals appear good or do I have a problem somewhere still ?
Scope settings are 5us 5volts/div
File Type: jpg 69240D37-8656-4499-9AE9-F41C2EBCD536.jpg (652.0 KB, 11 views)
File Type: jpg 59A5D86C-C4A3-41DB-BA8B-AAB3554F3EDF.jpg (623.0 KB, 11 views)
Audiopipe AP 3000 1DHide this!Advertise here!
Audiopipe AP18001D S Merlington Car Audio 3 12th November 2015 04:05 AM
Audiopipe AP-3002 S Merlington Car Audio 0 4th October 2015 06:09 AM
audiopipe 30001d amp oldschoolamp Car Audio 3 19th July 2015 09:36 PM
Audiopipe APK 2500 S Merlington Car Audio 5 17th March 2015 04:46 AM
Audiopipe ap30001d blazer40 Car Audio 15 4th October 2012 02:27 AM
Copyright ©1999-2019 diyAudio
