Rockford Fosgate Power 500bd no output.
Old 16th March 2019, 02:06 AM   #1
rhempz01 is offline rhempz01  United States
Default Rockford Fosgate Power 500bd no output.
The amplifier sounds as if everything NJ is functioning as intended. Yet there is no audio output. I have oscillation, a healthy power supply.
Old 16th March 2019, 02:16 AM   #2
Correction, has audio, with static and thumping from the switches.
Old 16th March 2019, 03:19 AM   #3
Perry Babin is offline Perry Babin  United States
Have you tried cleaning the pots and switches?
Is the audio clean at U4, pin 1?
If the switches thump loudly when switching positions, it could be due to an op-amp with significant DC on its output.
Old 16th March 2019, 06:43 AM   #4
Looks like there is some noise surrounding it. Grounded at the rca sheild.
Old 16th March 2019, 06:44 AM   #5
U4 pin 1 40hz 5v
Old 16th March 2019, 06:47 AM   #6
Are the RCA shield grounds intact?
With no RCAs plugged in, what's the resistance between the RCA input shields and the main ground terminal?
Old 16th March 2019, 08:03 AM   #7
.980kohm
Old 16th March 2019, 08:23 AM   #8
Old 17th March 2019, 07:23 PM   #9
Yes rca sheild grounds are in tach. It has a very distant static sound. Something is wrong. Its like it has a bad signal ground
Old 18th March 2019, 02:35 AM   #10
Do you read 0 ohms between the signal source RCA shield ground and the ground terminal of the amplifier?
Rockford Fosgate Power 500bd no output.Hide this!Advertise here!
Rockford Fosgate Power 851x output voltage problem urosb82 Car Audio 8 23rd October 2018 02:21 PM
Rockford 500bd seankane Car Audio 1 18th December 2017 06:54 AM
Rockford Fosgate M600-4D, Has power, No output. neo8222 Car Audio 1 15th June 2015 08:20 AM
Rockford fosgate power 500bd in protect chipper Car Audio 14 27th February 2013 01:16 PM
Help me with Rockford 500bd valterdaw Car Audio 7 19th May 2007 08:43 PM
Copyright ©1999-2019 diyAudio
