SPX pro audio amp   No audio output
Old 16th March 2019, 01:01 AM   #1
neonarossa is offline neonarossa  United States
Default SPX pro audio amp No audio output
I have +-15v on ICs 1-5
100hz Signal in & out ICs 1-4
No signal in or out IC 5
Rail voltage +29.44v /-29.46
Checked all drivers?
File Type: jpg Screenshot_20190315-182844_Samsung Internet.jpg (425.3 KB, 33 views)
Fluke 11 Multimeter- Mesr-100 ESR Meter- 862D+ Hotair/Solder Station- GJ S-993A Desolder gun- 19amp Power Supply- BK Precision 15mhz Scope
Old 16th March 2019, 01:20 AM   #2
Perry Babin is offline Perry Babin  United States
Have you operated all switches and pots through their entire range while listening for output to see if audio ever played through?
Old 16th March 2019, 01:33 AM   #3
Yes. Although the low/full/high switch is stuck in the middle.
I checked for signal on the pins under the board. Signal was present.
Old 19th March 2019, 12:09 AM   #4
Amp is fixed!! I removed the xover switch. Took apart and cleaned the corroded contacts and installed. Thanks again..
SPX pro audio amp   No audio outputHide this!Advertise here!
No audio output jl audio 500/5 troubleshooting Pbs64133 Car Audio 27 18th November 2018 02:44 AM
jl audio 500/1 rev3 no audio output ivkata Car Audio 9 1st December 2013 04:39 PM
JL Audio 300/4 Low Audio Output Troubleshooting Tip kds9591 Car Audio 3 25th December 2012 01:09 PM
Good books or videos on audio production, audio engineering, or audio editing tunks14 Everything Else 0 15th April 2011 10:00 PM
Cambridge Audio 640C No audio output PLEASE HELP! Kajman Digital Source 3 10th December 2007 09:45 AM
Copyright ©1999-2019 diyAudio
