Rockford Fosgate Power 1501BD
Old 15th March 2019, 07:34 PM   #1
caraudioguy2100 is offline caraudioguy2100
Default Rockford Fosgate Power 1501BD
Someone tried repairing this amp before .
They have 10 ohm gate resistors with 3205íS installed are the 10 ohm gate resistors fine or should I use the 47 ohm ?
Also does anyone know what value C60 is ?
It sits behind the LM337 regulator
Also the value of R44 ?
It sits next to the transformer
Old 15th March 2019, 07:47 PM   #2
Perry Babin is offline Perry Babin  United States
I leave the 10 ohm gate resistors. Some use 47. Either will work. All need to be the same value.
C60 is the same as C59, 100uF@25.
R44 is 10 ohms.
Old 16th March 2019, 12:05 AM   #3
Do you know what the value is of the gate resistors for the outputs ?
Someone switched them all and I donít think they are the correct value
Old 16th March 2019, 12:38 AM   #4
seankane is offline seankane  United States
seankane's Avatar
If memory serves I believe they are 15 ohm
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 16th March 2019, 12:40 AM   #5
Thatís what I thought but wasnít sure .
They have 27 ohm in there now
Old 16th March 2019, 12:45 AM   #6
seankane's Avatar
I have also seen 22 ohm in there from the factory as well, I have also seen a mix of 15 ohm and 22 ohm from the factory.
Old 16th March 2019, 12:57 AM   #7
Anyone have a schematic for this amp ?
amprepairguy@hotmail.com
I noticed someone has switched other caps in here to the wrong value and other parts as well so Iím in need of a schematic to figure this amp out since there are a lot of wrong values
Old 16th March 2019, 01:13 AM   #8
seankane's Avatar
Here are some documents that may help.
Old 16th March 2019, 02:53 AM   #9
In the schematic half the outputs have 15 ohm gate resistors the other half have 22 ohm gate resistors .
Can I use 15 ohm resistors for all of the outputs ?
Old 16th March 2019, 03:12 AM   #10
I'd suggest that you use the original values but it should be OK with all 15 ohm resistors.
Rockford Fosgate Power 1501BDHide this!Advertise here!
Rockford Fosgate power 1501bd amp it up Car Audio 9 15th October 2018 01:55 AM
Rockford fosgate 1501bd power series PROBLEMS! MarioRestucci Car Audio 7 31st October 2017 07:53 AM
Rockford Fosgate Power 1501BD S Merlington Car Audio 17 12th May 2015 07:40 PM
rockford fosgate 1501bd RockfordFIx Car Audio 22 30th October 2013 09:03 PM
Rockford Fosgate 1501bd Repairing josesony68 Car Audio 35 11th September 2011 03:24 PM
Copyright ©1999-2019 diyAudio
