Sundown SAZ3500D
I just repaired the output stage in one of these and it used IRFP360LCPBF.
The repair was a success and the amp is being driven hard and working great.
You will definitely have to replace the IRS21844SPBF on the driver card.
There is one driver for each side of the outputs. I replaced the one and one side of the outputs and it works great. If you have blown outputs the driver will be defective.
You will have to change all on both sides if you use these FET's. I think I purchased them for around $3.50 each if memory serves? I believe I used arrow or mouser.
Here is a picture of the audio driverboard
I never use hot-air to install ICs. You can use paste or regular solder.
Not all irons will be accurate. I think I set mine to about 600F. You want to get everything cleaned and prepared so that you just have to touch the terminals to get them soldered.
The following video is so bad that it may take down the entire internet. It was also before beta blockers so there is nothing good about it but it does show how quickly you can solder the terminals of an SMD IC.
YouTube
