Rockford Fosgate 2500.1bdcp, questions.
Old 16th March 2019, 02:27 AM   #71
rhempz01 is offline rhempz01  United States
ok, will do
Old 16th March 2019, 03:16 AM   #72
Perry Babin is offline Perry Babin  United States
Why don't you have full supply voltage (12-15v) on the collectors of the NPN drivers?
Old 16th March 2019, 06:48 AM   #73
I do have 12.51vdc on them all.
Old 16th March 2019, 06:59 AM   #74
Current drive with a load. Im going to be using irfp064n for the power supply. I should use all 47ohm gate resistors as well?
Old 16th March 2019, 08:48 AM   #75
Sean has repaired a lot more of these than I have so he may have a different opinion. I'd use the original values (half 60.4, the other half 47.5) all 47 ohms will likely be perfectly OK as well.
Old 16th March 2019, 08:55 AM   #76
Ill message him. Thanks perry.
Old 16th March 2019, 06:51 PM   #77
Perry despite my best efforts the power supply mosfets still overheat. If i attempt to power up the amplifier in the q6-q5-q4 location. The amplifir instantly drew 10amps of current and the mosfet in location q5 was hot within seconds? Shorted transformers?
Old 16th March 2019, 07:27 PM   #78
new mosfets and a drive signal looks good loaded down.
Old 16th March 2019, 10:24 PM   #79
Post the waveform of the hottest FET, taken directly from the leg of the FET (not from any other point in the drive circuit). Do not connect B+ so there will be no excessive current draw.
Old 16th March 2019, 11:04 PM   #80
Hotest fet drive at the leg.
Rockford Fosgate 2500.1bdcp, questions.Hide this!Advertise here!
T1500-1bdcp Rockford fosgate DREW028 Car Audio 17 14th March 2019 05:57 PM
Rockford Fosgate T2500-1bdcp seankane Car Audio 44 14th March 2019 04:12 AM
Rockford Fosgate T2500-1BDCP PaleFaceRider202 Car Audio 4 5th February 2018 11:34 PM
Rockford Fosgate T-2500-1BDCP josesony68 Car Audio 15 6th November 2016 08:04 AM
Rockford Fosgate T1500-1BDCP ------ No Output spooney Car Audio 8 27th August 2013 11:46 AM
Copyright ©1999-2019 diyAudio
