Rockford Fosgate 2500.1bdcp, questions.
Old 13th March 2019, 12:05 AM   #31
Perry Babin is offline Perry Babin  United States
Post #20?
Old 13th March 2019, 12:06 AM   #32
seankane is offline seankane  United States
seankane's Avatar
No you should not. This amp here has 25mv at the highest reading.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 13th March 2019, 12:15 PM   #33
Is it the red or the yellow LED that's flashing briefly?
I have a T1000-1bdcp here and the problem is the protect LED is flashing. The problem appears to be associated with U1. I'll check a bit more carefully when I get into the shop tomorrow.
Old 13th March 2019, 01:04 PM   #34
rhempz01 is offline rhempz01  United States
Yellow thermal. It goes on then off, on then off.
Old 14th March 2019, 04:11 AM   #35
From a problem on another model, try clamping another non-polarized capacitor in the speaker terminals (n place of a speaker).
If the amp still refuses to come on and play, you may have a shorted inductor. If it does play, you may have a bad capacitor or bad solder connections on it/them.
Old 14th March 2019, 04:49 PM   #36
The amp stops flashing into thermal protection with a cap in the terminal. I can see the 40hz but, the gain is not effective if i turn. The power supply fets are heating up, that is possibly where my current is coming from. The six closest to the terminal. Im going to pull them and test them.
The regulators all have the proper voltage on them.
6.12vdc on the rca sheilds.
Old 14th March 2019, 05:16 PM   #37
Power supply fets are leaking. One is shorted, stuck in its off position.
Old 14th March 2019, 05:59 PM   #38
These were loose wire strands as well as a half or a potentiometer floating around inside the amplifier. Also very little thermal paste/tension on the mosfets which caused the fets to have like a hot spot area around them.
Old 14th March 2019, 08:03 PM   #39
Without the rectifiers in circuit, no matter the mosfet used in q4-6 it instantly heats up.
Old 14th March 2019, 08:47 PM   #40
With only ground and remote connected, what does the drive waveform look like?
Rockford Fosgate 2500.1bdcp, questions.Hide this!Advertise here!
T1500-1bdcp Rockford fosgate DREW028 Car Audio 17 14th March 2019 05:57 PM
Rockford Fosgate T2500-1bdcp seankane Car Audio 44 14th March 2019 04:12 AM
Rockford Fosgate T2500-1BDCP PaleFaceRider202 Car Audio 4 5th February 2018 11:34 PM
Rockford Fosgate T-2500-1BDCP josesony68 Car Audio 15 6th November 2016 08:04 AM
Rockford Fosgate T1500-1BDCP ------ No Output spooney Car Audio 8 27th August 2013 11:46 AM
Copyright ©1999-2019 diyAudio
