Needing help repairing an Orion HCCA 250 Digital Reference
Old 9th March 2019, 06:34 AM   #11
Chopperbuilder is offline Chopperbuilder  United States
Yes, a 50hz test tone. It was clipping with the volume set pretty low.
Multimeter: Blue Point - Model: MT586B / Oscilloscope: Leader - Model: LBO-524 / Power Supply: Modified computer 500 watt
Old 9th March 2019, 06:40 AM   #12
Perry Babin is offline Perry Babin  United States
With the scope set the same as when you took the post 7 photo, how far up does the scope trace deflect if you touch the probe to the rail voltage?
What is the rail voltage, measured with a multimeter? black probe on the RCA shield
Old 9th March 2019, 06:43 AM   #13
This is using the 100hz test tone you provided. Volume turned down low.
Also attached a photo of the setting I had to use to get a wave form.
Old 9th March 2019, 06:58 AM   #14
Did you see post #12?
Old 9th March 2019, 06:59 AM   #15
When I touch the probe to the rail voltage, the trace defects from where it is in the photo to where the yellow line is.
Rail voltage is at +34.98v and -34.98v.
Old 9th March 2019, 07:03 AM   #16
So... the amp is clipping at about 10v with a rail voltage of 30+v?
Do you have 15v on the power supply pins of all of the op-amps?
Old 9th March 2019, 07:51 AM   #17
If I were to say the amp is clipping at about 10v, I would be guessing but it sounds about right.
I do not have +/- 15v on the power supply pins of any of the op-amps. Given that I tested the right pins... See attached photo for the pins I tested and voltages.
Old 9th March 2019, 07:59 AM   #18
15 is sort of a generic term. I can't remember which amps use 10 or 18 or anything in-between.
You're not pointing to the power supply pins of the NE5534s.
Old 9th March 2019, 08:04 AM   #19
Will you point out the power supply pins for me? I'm apparently not reading the data sheet for the NE5532N correctly.
Old 9th March 2019, 08:08 AM   #20
Aren't the ICs near the rail caps NE5534s, not NE5532s?
Needing help repairing an Orion HCCA 250 Digital ReferenceHide this!Advertise here!
Again needing help fixing Orion HCCA 225 Digital Reference Chopperbuilder Car Audio 123 13th July 2018 02:27 AM
Orion 250 HCCA Digital Reference Gioba Car Audio 4 15th October 2013 01:13 PM
orion 2100 hcca digital reference timwebb Car Audio 1 10th March 2013 07:09 PM
Orion HCCA 225 Digital Reference with Low Output 0ldSch00lf00l Car Audio 7 4th February 2011 04:32 AM
Orion 225 Hcca digital reference Bunn Swap Meet 0 30th January 2009 12:25 PM
Copyright ©1999-2019 diyAudio
