Mtx ta92001 distorted output.
Old 10th April 2019, 12:08 AM   #171
kfx5050 is offline kfx5050  United States
At the resistor yes at the op amp no.
Old 10th April 2019, 12:17 AM   #172
Perry Babin is offline Perry Babin  United States
Confirm that you have audio on both pins 1 and 7 of the 5532 near the header.
Old 10th April 2019, 10:46 PM   #173
yes I have the 50hz tone on pin 1&7 near the pre amp board plug
Old 11th April 2019, 12:10 AM   #174
Is R4011 within tolerance?
Do you read 2000 ohms between pin 1 of the header op-amp and pin 3 of the op-amp near the heatsink?
Old 12th April 2019, 03:37 AM   #175
R4011 is showing 1.832kohms
The op-amp right cross from r4011 the one closest to the heatsink is what your referring too right? If so, It's reading 1.824kohms
Old 12th April 2019, 03:48 AM   #176
I'm trying to determine why the signal isn't making it from the dual op-amp near the header to the two inputs on the 5534. You won't see the input to the inverting input while the op-amp is functioning normally but you should see it on the non-inverting (pin 3) input.
Old 17th April 2019, 11:43 PM   #177
Ok I order a new radio just arrived. I have a 50hz test tone at 1.055volts going into the amp on one side of r4016 I have the 50hz tone on the ather side I do not have the 50hz tone
Old 18th April 2019, 08:16 AM   #178
On R4016, you should only see the signal on one side of the resistor. On R4011, you should see it on both terminals.
Mtx ta92001 distorted output.Hide this!Advertise here!
KMD GV100D Low distorted output joebags Instruments and Amps 2 20th February 2014 10:37 AM
JL 500/1 distorted output mbates14 Car Audio 3 2nd October 2012 06:35 PM
Amp with distorted output Mote Car Audio 5 23rd August 2012 07:17 PM
Distorted output towards end of discs Kei Digital Source 8 16th May 2012 08:26 AM
MTX 4250D distorted output bil Car Audio 3 5th April 2008 03:30 PM
Copyright ©1999-2019 diyAudio
