Kicker CXA1200.1
Kicker CXA1200.1
Old 21st February 2019, 12:23 AM   #1
bikerboy87 is offline bikerboy87
Default Kicker CXA1200.1
Recently bought this amplifier used online, got it hooked up and when im only at mid volume i noticed it would start to distort and the red protect light would flicker when the bass hit.
I opened it up and noticed 2 of the 6 80v 2200uf 105 celcius capacitors were bulged on the top. They tested good with a multimeter set to capacitance but i still want to replace the anyways. My problem is that they measure 22mm in diameter by 30mm tall. The only capacitors i find online close to this size say they are 25mm x 30mm and with the original capacitors installed they already almost touch eachother so i dont think they will fit.
Hoping someone knows where to find this size
Old 21st February 2019, 01:50 AM   #2
seankane is offline seankane  United States
seankane's Avatar
Do you have more room for height?
22X35 are available
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 21st February 2019, 01:56 AM   #3
Im gonna check tomorrow when i get to work where i have a caliper to measure.
Old 21st February 2019, 05:03 AM   #4
Perry Babin is offline Perry Babin  United States
For those a bit short on calipers, you can buy digital calipers for $3 each on ebay. They're plastic and only have a resolution of 0.01" but work perfectly fine for measuring caps and such.
Old 22nd February 2019, 12:54 AM   #5
22x35 will fit but i cant find any in stock anywhere
Old 22nd February 2019, 04:45 AM   #6
Did you try entering the manufacturer's part number into octopart?
Old 23rd February 2019, 12:06 AM   #7
seankane's Avatar
Mouser has 22X35
Kicker CXA1200.1Hide this!Advertise here!
Kicker Cxa1200.1 power issues rhempz01 Car Audio 3 22nd October 2018 01:44 PM
Kicker zx 350.2 help Eaudio2013 Car Audio 26 17th October 2017 03:32 PM
Kicker ZX 200.2 Fummins Car Audio 5 5th May 2015 06:59 PM
kicker 450.2 timwebb Car Audio 5 26th May 2010 05:59 AM
Kicker L7 skooter Car Audio 5 25th September 2008 11:36 PM
Copyright ©1999-2019 diyAudio
