Fire Audio 2200D
Fire Audio 2200D
Old 18th February 2019, 01:00 PM   #21
Perry Babin is offline Perry Babin  United States
Is the jumper soldered in the locations I described?
Old 18th February 2019, 01:07 PM   #22
chrisg4 is offline chrisg4  South Africa
no, i was afraid i might fry the hip4080 again...
Old 18th February 2019, 01:10 PM   #23
The high side is floating. That's why you can't see a good signal. Measure it with a meter, gate to source and compare to the two banks with good signals.
What sort of scope do you have?
Old 18th February 2019, 01:15 PM   #24
on the good sides i get 6v and the other banks 0.06v
beckman industrial analog 9020
Old 18th February 2019, 01:27 PM   #25
Black probe on pad 3 and red probe on pad 1?
I didn't know if you had a battery operated scope.
Old 19th February 2019, 05:33 AM   #26
get below wave forms
Old 19th February 2019, 06:15 AM   #27
Were you driving a signal into the amp when the photos were taken.
Are you still only getting a signal on the low-side FETs?
What is the DC voltage across pins:
1 and 19 (black)
10 and 12 (black)
Old 19th February 2019, 06:24 AM   #28
yes i drove a 100hz sine wave
those waves appear on both high and low side
1 and 19 : from 2.1v fluctuates to 9.8v and then drops back to 2.1v
10 and 12 : same as above
Old 19th February 2019, 06:37 AM   #29
How did you finally get to see the high side?
Old 19th February 2019, 07:18 AM   #30
using the scope ground on source legs gave the above wave forms
Fire Audio 2200DHide this!Advertise here!
Soundstream DTR1.2200D Formas Car Audio 7 27th May 2018 07:08 PM
Help Fire - Need New Sub Amp ODougbo Solid State 6 23rd December 2012 08:36 PM
FS: Audio Transformer Fire Sale dsavitsk Swap Meet 3 10th June 2010 06:17 PM
Which way to fire my sub? Gorbee Subwoofers 24 12th September 2006 12:59 AM
Amp on Fire! peter5 Solid State 6 7th January 2002 11:35 AM
Copyright ©1999-2019 diyAudio
