Fire Audio 2200D
Fire Audio 2200D
Old 11th February 2019, 08:05 PM   #11
chrisg4 is offline chrisg4  South Africa
1. Yes
2. Yes
3. Not sure, removed remote when it smoked
4. No, no outputs were installed when I replaced it.
Old 11th February 2019, 08:25 PM   #12
Perry Babin is offline Perry Babin  United States
Both large 1 ohm resistors serve the same purpose and connect to identical circuits. Why did only one smoke?
Old 12th February 2019, 05:55 AM   #13
i think i may have damaged the HIP4080, i discovered a small solder bridge on one of the other banks
Old 12th February 2019, 06:01 AM   #14
Did you try the old and the replacement to see if either worked (no outputs)?
Old 12th February 2019, 06:36 AM   #15
yes i did swap them, the old hip4080 gets really hot
Old 12th February 2019, 06:37 AM   #16
it could have been the hip4080 that smoked
Old 12th February 2019, 09:40 AM   #17
resistor values:
Old 13th February 2019, 04:56 AM   #18
replaced the resistors, how do i avoid damaging another hip4080?
Old 17th February 2019, 06:25 PM   #19
They are fragile. The best you can do is to check all connected components and make sure that you don't have any solder bridges.
If this amp powers the 4080 through a regulator, make sure that the output voltage is pretty close to 12v.
Old 18th February 2019, 12:59 PM   #20
I replaced the hip4080
i do get drive waves on all banks, two banks have good waves but the other two are very small
Fire Audio 2200DHide this!Advertise here!
Soundstream DTR1.2200D Formas Car Audio 7 27th May 2018 07:08 PM
Help Fire - Need New Sub Amp ODougbo Solid State 6 23rd December 2012 08:36 PM
FS: Audio Transformer Fire Sale dsavitsk Swap Meet 3 10th June 2010 06:17 PM
Which way to fire my sub? Gorbee Subwoofers 24 12th September 2006 12:59 AM
Amp on Fire! peter5 Solid State 6 7th January 2002 11:35 AM
Copyright ©1999-2019 diyAudio
