Kicker cxa300.1 help please
Old 9th February 2019, 09:59 PM   #1
jayjs730 is offline jayjs730
Default Kicker cxa300.1 help please
Hello I would appreciate it very much for some help on this amplifier .I replaced power transistors,audio ,gate resistors and rectifiers.
ITS still stuck in protect mode ,only one rectifiers is getting power and resistor r105 pops soon as power is applied.[
File Type: jpg 15497530750701339435478297490573.jpg (1,022.4 KB, 31 views)
Old 9th February 2019, 10:50 PM   #2
PapaZBill is online now PapaZBill  United States
PapaZBill's Avatar
R105 4.7 ohm resistor is the B+ for IC3-18021 gate driver. The Pins 1 and or Pin 2 is shorted and causing R105 to burn up. This is fairly common when the power supply fails. Replacing IC3 will most likely fix the problem.
Once you have everything replaced, IC3, Gate resistors 33 ohm resistors, etc and before you install the PS mosfets-AOT460's, remove R68-4.7Kohm and power the amp. Check the gate pads for drive with a scope if possible or voltmeter. Post screenshots or voltages readings.
Any sufficiently advanced technology is indistinguishable from magic.
Arthur C. Clarke
Old 9th February 2019, 10:55 PM   #3
Thank you so much I highly appreciate your help .I asked Perry but he said hes not familiar with this board.So you are a life saver I will let you know how I make out,Jeremy
Old 10th February 2019, 02:15 AM   #4
PapaZBill's Avatar
Check your PM, I found the MP18021 at Mouser.
Arthur C. Clarke
Kicker cxa300.1 help pleaseHide this!Advertise here!
Kicker CXA300.4 no audio troubleshooting help. rhempz01 Car Audio 19 4th November 2018 03:15 PM
Kicker CXA300-4 Won't power on. rhempz01 Car Audio 8 25th July 2018 07:08 PM
kicker l7 2 ohm cintr113 Car Audio 15 14th March 2016 11:00 PM
Kicker ZR vincegironda Car Audio 21 26th March 2015 10:21 PM
Kicker 750.1 mike49504 Car Audio 9 19th February 2012 12:50 PM
Copyright ©1999-2019 diyAudio
