Sweep with the probe showed no voltage. Attached are pictures of the trace on the other side of the board. There is a resistor on the top side connected to the trace for pin 1 (the yellow "2" is on top of one of the pins of that resistor in the one photo).
Sorry for the delay.
On the amp I have here, removing the 6488 did nothing to the voltage on pin 1. Pins 2 and 3 follow pin 1. That's why they all changed. You can reinstall the 6488.
Pin 1 is driven by the protection circuit transistors. Pull them to see if that allows the amp to power up.
- General Interest
- Car Audio
- Once again need help fixing Orion HCCA 225 Digital Reference
