US Amps AX-1500DE
US Amps AX-1500DE
Old 11th February 2019, 02:39 PM   #51
Perry Babin is offline Perry Babin  United States
Does removing that op-amp affect the voltage on the output?
Was the 4558 new?
Old 11th February 2019, 02:51 PM   #52
caraudioguy2100 is offline caraudioguy2100
Yes if I remove that opamp the voltage on the output drops to 0
And that opamp was new I can replace it again with a TL072 or a LM833
Old 11th February 2019, 03:03 PM   #53
Are the positive and negative power supplies for that op-amp approximately equal?
Old 11th February 2019, 03:18 PM   #54
Yes I have -11.92 and +11.90
Old 11th February 2019, 03:52 PM   #55
I think I found the problem one of the other opamp is defective the IL4558 is defective pulling the voltage down on the other ic .
Old 11th February 2019, 03:58 PM   #56
Is the circuit in the attached diagram close to what you have?
Old 11th February 2019, 04:07 PM   #57
Yes
Old 11th February 2019, 07:28 PM   #58
Which op-amp on the diagram corresponds to the one that has DC offset in your amp?
US Amps AX-1500DEHide this!Advertise here!
US Amps AX-1500DE resistor info Deadly Sones Car Audio 0 7th May 2017 06:01 PM
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 20 12th May 2015 12:23 PM
Commercial Pre-Pre Amps for Moving Coil Cartridges (MC Head Amps) in Common Base tiefbassuebertr Analogue Source 8 11th December 2012 08:54 AM
Burr Brown op amps,in amps,power op amps for sale magneticnorth Vendor's Bazaar 1 23rd September 2010 10:50 PM
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 10:27 PM
Copyright ©1999-2019 diyAudio
