Hello I had replaced some small elana caps on my alpine 3558 but I'm questioning my replacement choice after reading on audio grade caps. Before I start reassembly wanted some input on the capacitors I replaced. Originals were all elna 10uf 16v. They have cers stamped on them but I could not find any info on a elna cers series. I replaced them with nichicon UKT1C100MDD 10uf 16v audio grade. Since I believe these were in the power supply not audio path was that a good choice. If I had more info on the originals I would have just matched those. Any thoughts on if the ones I used are a good choice. Any suggestions on better replacements. Thanks
