JL audio 500/1v2 power supply problems.
Old 22nd January 2019, 08:55 PM   #21
rhempz01 is offline rhempz01  United States
I removed one from the amplifier with the regulated voltage problem for now. And rewound the torrid. With 28gauge 8 strands at the same length as what came off the spool. Wound it up I think the OEM wire is 30gauge. And when it was wound the tester reads .4mH
Old 23rd January 2019, 01:53 AM   #22
Perry Babin is offline Perry Babin  United States
40uH is about what I've found, checking them. If you wound with the same number of turns and got the cores tightly back together, it's likely OK.
Old 23rd January 2019, 02:32 AM   #23
Yes, i wound identical and fit back it the ferrite core i taped it back up. The amp is working fine. I used it in the the other amplifier. Thanks for the help perry.
JL audio 500/1v2 power supply problems.Hide this!Advertise here!
a75 power supply problems dinu Pass Labs 97 10th October 2006 06:45 PM
Power supply problems Devius Power Supplies 8 2nd July 2006 03:17 AM
Audio Electronics Supply AE-1 problems 240z4u Tubes / Valves 6 10th December 2004 11:05 PM
problems with my power supply Pablo Solid State 10 4th June 2004 01:02 PM
Copyright ©1999-2019 diyAudio
