Thermal solutions for car amps
Old 6th March 2019, 04:25 PM   #21
jkrokenberger is offline jkrokenberger  United States
If the MT+ works well please let us know. I'd be willing to try it out. Is that Rodek a Zed? Very nice amp to keep alive instead of let go to the shelf of misfit amplifiers.
Old 6th March 2019, 10:25 PM   #22
Cartel is offline Cartel
I'm sure it will work great.
Its almost 3 times better than regular MT.
I'm using 2mm but there is 1.5 and 1mm also.
Old 6th March 2019, 11:34 PM   #23
Well its back together.
I dried the cardboard and re-used it.
It fits almost perfectly flush with nothing on the big mosfets and the nylon shims from the factory work perfect on the smaller to220's but that thin cardboard must be needed to absorb vibrations and act as a gasket.
Its working great again I dont smell anything getting hot.
I put some white glue on the nuts.
I didn't crank them down this time, just snugged them to like 3 or 4 ft/lbs if that.
I think I went way too tight last time.
Thermal solutions for car ampsHide this!Advertise here!
Biasing/thermal compensation of Thermal Trak transistors Bob Cordell Solid State 163 23rd March 2019 10:53 PM
heatisnk copper shims, thermal paste or thermal pad? vishalk Solid State 11 12th March 2018 05:30 PM
Worth doing cheap "thermal protection fuses" in hot amps? cfcubed Pass Labs 4 15th June 2008 02:27 AM
help with Thermal Impdeance vs. Thermal Conductivity Eric Pass Labs 4 22nd July 2005 07:23 PM
Copyright ©1999-2019 diyAudio
