JL300/2 power supply problem? - pls help
Old 15th January 2019, 07:58 AM   #1
nonprof is offline nonprof
Default JL300/2 power supply problem? - pls help
Hi!
Somebody help me on JL amp 300x2? dont have problem if the volume level is minimum and low. But If you increase the volume/gain the rail voltages drops to +-12volts or lower and sound output become distorted. I notice if no load, the rail voltages just reaches to +-24V, I know these voltages are low and not normal.
Checking the signal at primary and secondary transformer, I can't see a perfect square wave coming in and out.
Happy New year! Thank you!
Old 15th January 2019, 12:46 PM   #2
Perry Babin is offline Perry Babin  United States
The supply is heavily regulated so there will be no square wave. For some amps, you can reduce the input supply voltage to force a perfect square wave but the low-voltage shutdown in this amp may shut the amp down before you get to a perfect square wave.
Is the waveform on the primary collapsing when the rail voltage drops?
Old 15th January 2019, 08:29 PM   #3
Cartel is offline Cartel
possible related?
YouTube
Old 16th January 2019, 01:14 AM   #4
Hi Perry, The primary and maybe the secondary waveforms too, making a nice square wave when the rail voltages drops or increasing the sound level. The sound becomes distorted too. Thanks!
Old 16th January 2019, 01:19 AM   #5
If the waveform is going square on the gates and the drains and the drains are swinging to 2x the supply voltage, I'd suspect that the problem is on the 12v supply line. Can you use a supply that will keep the input voltage well over 12v?
Old 16th January 2019, 02:32 AM   #6
Thank you. I'll do.
Old 17th January 2019, 01:47 AM   #7
Hello Perry, I confirmed that my 12V supply not drops below 12v, I monitored it on the top(Drain) of power mosfets and at the terminal of the power supply.
I have a question
1.Why my rail voltages is measuring +29V and -22V (neg probe on -supply) only with load. And It drops when has a load and kickin. What is the normal rail voltages without load?
Other symptoms:
- There is no LEDs lit coming out...
- When there is a music the rail voltages drops to +-12V, respect to -supply.
- Turning off the amplifier through remote signal, you can still hear a very low music and gone.
Please see attached image taken from the output rectifier with load. looks nice...
Thank you!
Old 17th January 2019, 10:16 AM   #8
Are there any broken legs on the rectifiers?
Old 22nd January 2019, 05:18 AM   #9
Hello Perry, there are no broken legs at rectifier.
I notice that rail voltages are regulated at +-12Volts only. Do you have an idea how to raise the rail voltages?
Old 22nd January 2019, 09:02 AM   #10
Pin 1 is the feedback for the voltage regulation. It goes back to U701 on the PS driver board. Post the DC voltage on all terminals of U701.
JL300/2 power supply problem? - pls helpHide this!Advertise here!
supply power problem captaincrazy Power Supplies 5 18th February 2013 03:52 PM
power supply problem goodsguys Power Supplies 16 14th January 2013 03:10 AM
power supply problem chopchip Tubes / Valves 96 24th July 2010 02:03 PM
Power Supply problem Landoctor Chip Amps 3 8th September 2007 08:50 PM
Power supply problem??? wintermute Solid State 22 12th October 2003 08:20 AM
Copyright ©1999-2019 diyAudio
