Alpine 3558 wont power up
Old 18th January 2019, 03:52 AM   #11
Perry Babin is offline Perry Babin  United States
All you want to do is reestablish the connection to B+ if that's what's missing. Find the closest cap on the B+ and connect to the IC with a jumper wire.
Old 18th January 2019, 11:59 PM   #12
bmore5077 is offline bmore5077  United States
I checked for continuity from cap to cap top to bottom of the board to check vias and to the ic chip pin. It was good. Seems like there is nothing but the 13.2 v from my power supply on this amp no matter where I check. The center pins of the power fets have 13.2v. Oddly on the 40v rails and the capacitors I have like 220mv. Must be something in power section.
Old 19th January 2019, 12:55 AM   #13
Do you have 12v on both terminals of L805?
Old 20th January 2019, 12:56 AM   #14
Yes sir I do.
Old 20th January 2019, 01:11 AM   #15
Caps have like 220mv
Old 20th January 2019, 01:35 AM   #16
Measurements from driver ic 801 on panel main rear. The board has 2 ic chips. One for each side as its split into 2 pieces.
Pin1. 0mv
Pin 2 0mv
Pin 3 .2mv
Pin 4 6.8mv
Pin 5 254.7mv
Pin 6 254.7mv
Pin 7 13.09v
Pin 8 .2mv
Pin 9 8.1mv
Pin 10 1mv
Pin 11 196.5mv
Pin 12 .2mv
Pin 13 .6
Pin 14 1mv
Pin 15 .3mv
Pin 16 .4mv
Pin 17 196.4mv
Pin 18 .790mv dropping steady
Pin 19 3mv
Pin 20 2.6mv
Old 20th January 2019, 01:39 AM   #17
The above measures is for one ic chip as I can only get to the rear main board side. The same side that L805 was on. The only one that seems good is pin 7 for remote.
Old 20th January 2019, 02:19 AM   #18
The break seems like it has to be in the rectangle in the attached diagram. It could be on either side of the board.
Old 20th January 2019, 02:30 AM   #19
Ok I'll start trying to track it down. I was thinking that because of 12v at the inductor but not the caps or ic. Thanks for your help.
Old 20th January 2019, 03:05 AM   #20
Thanks for taking the time to look at the schematic and help me.
Alpine 3558 wont power upHide this!Advertise here!
Alpine 3558 service manual needed bmore5077 Car Audio 9 26th November 2018 01:05 AM
Alpine 3558 amp service manual an2ny888 Car Audio 1 26th August 2018 11:20 PM
alpine 3558 power section nonprof Car Audio 1 12th June 2017 11:43 AM
Alpine 3558 -I need help! caraudiofan Car Audio 5 19th October 2016 06:50 PM
alpine ivx-c806 wont power up mekaiver Car Audio 4 28th August 2011 11:04 AM
Copyright ©1999-2019 diyAudio
