Capacitors help
A capacitor labeled 2200uF 100wv 105c what are the voltage rating of these capacitors? 100v capacitors I can't find that size.
It's for a power acustik amplifier I found some, but all were too wide or too tall. 22*25mm is the size of these but 22*30 will work maybe 35mm tall can squeeze, I have 22*40mm now 100v and I will have to alter the bottom plate some to make them fit. I added a rail washer to fit them
