Alpine MRP-M1000 with rail voltage but no output
Old Yesterday, 03:06 AM   #61
Perry Babin is offline Perry Babin  United States
Try this...
Signal source >1> cap >2> 1k resistor >3> 10k resistor >> shield of signal source.
Post the AC voltage on points 1, 2 and 3 with the scope ground connected to shield of the signal source. Do this with no connection to the amp. Set the signal source to full volume. Try it at around 20kHz.
Old Yesterday, 04:08 AM   #62
mild2wild is offline mild2wild  Trinidad and Tobago
I measured the ipod output using the 1khz tone first since it was consistent and stable. My scope does not have AC coupling so I used my voltmeter, black probe connected to RCA shield ground.
Ipod - capacitor 1.076v
Capacitor - 1k resistor 1.058v
1k resistor to 10k resistor 0.958v
10k resistor to shield ground 0.00
Old Yesterday, 04:30 AM   #63
The ipod playing the sweep track. The ac voltage is half that of the other track playing 1khz. The high and low frequencies act differently. 1st reading is 20-200hz approximately, the second is close to 20khz.
Ipod - capacitor 0.55v
Capacitor - 1k resistor 0.52v
Old Yesterday, 04:30 AM   #64
That's about what it should be.
Do it again but connect the 1k resistor to ground (bypass the 10k). What is the voltage at the ipod and at the resistor/capacitor?
Do this with 1k and 20kHz signals.
You can use your scope.
Alpine MRP-M1000 with rail voltage but no outputHide this!Advertise here!
Alpine MRP-M1000 S Merlington Car Audio 34 15th February 2015 06:07 AM
Alpine MRP-M1000 S Merlington Car Audio 3 22nd October 2014 10:07 PM
Alpine M1000 technician1313 Car Audio 1 2nd January 2013 12:54 AM
Alpine MRP-M1000 mike49504 Car Audio 20 4th June 2011 04:37 AM
Alpine MRP-M1000 mike49504 Car Audio 7 30th January 2011 10:57 PM
Copyright ©1999-2019 diyAudio
