JL Audio 1000/1v1 low voltage light
Old 17th December 2018, 03:44 AM   #21
Perry Babin is offline Perry Babin  United States
Was Q506 out of the circuit when you read 0,06v?
Old 17th December 2018, 04:13 AM   #22
mild2wild is offline mild2wild  Trinidad and Tobago
I don't know if these outputs are just shorting out on me during this process but your question about 506 caused me to revisit it. I discovered it shorted between all 3 legs. I know it wasn't in that condition before. The previous testing had Q504 unpopulated and all others populated. I replaced Q506 and inserted a replacement into Q504 and retested.
Q500/501 5.4v
Q502/503 4.0v
Q504/505 5.3v
Q506/507 4.0v
Old 17th December 2018, 04:41 AM   #23
That looks much better. If you don't see any other problems, reinstall the two capacitors and clamp all FETs and see if it will power up.
Old 17th December 2018, 07:09 AM   #24
Reassembled and it powered up. Getting 115v at the bus bars near the outputs and 58v at the output terminal. Tested for audio at a low level and it is playing clean so far. There was some sparking that came from the ends of the resistors in between the 2 rows of capacitors, the 4R7 and 2R7 resistors, so I resoldered the ends as best as I could reach with the soldering iron. I will order some and change them. Also one of the capacitors next to them appears to have a bulging top so I will change that also. I will still insert an insulator under the green transformer winding.
Is there anything else I need to do to make sure the amplifier is fully repaired and reliable?
JL Audio 1000/1v1 low voltage lightHide this!Advertise here!
JL Audio 1000/1 No DC voltage at speaker terminals ref ground. kds9591 Car Audio 4 29th November 2018 05:42 AM
Using a lower voltage indicator light than supply voltage - Safe/acceptable method? DarkDeepRed Construction Tips 12 9th March 2016 02:06 PM
JL Audio 1000/1 low ohm light luigidedom Car Audio 2 20th December 2014 10:31 PM
JL 1000/1 V1 Has power but Low ohm light is on with sub and rca's unplug off amp superjoey01 Class D 0 16th July 2012 05:56 AM
JL 1000/1 Slash v1 Has low ohms and low volts light on superjoey01 Class D 1 15th July 2012 05:14 PM
Copyright ©1999-2019 diyAudio
