Rockford P8002
Rockford P8002
Old 7th December 2018, 02:32 AM   #1
seankane is offline seankane  United States
seankane's Avatar
Default Rockford P8002
Hello all. Working on a P8002 board number PC-4708-B.
I replaced all the outputs, gate resistors and source resistors in this amp. The amp powers and idles fine, and will bias. It also produces clean audio on both channels. I did also replace some smd diodes and transistors and various resistors.
My question is about the bias. It draws current sooner in the pot rotation than I'm used to seeing and mv readings across the source resistors vary from .2mv to 1.6mv
Should they all have the same readings or is this normal?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 7th December 2018, 03:05 AM   #2
Perry Babin is offline Perry Babin  United States
The threshold voltage may be lower than the original FETs.
The threshold voltage of the FETs or the source resistor actual value can make a difference between the parallel resistor readings. A better test is to drive the amp to about 10v AC into a dummy load and then measure the voltage across the source resistors. They should read very nearly the same with that test (within a few percent of each other).
Old 7th December 2018, 03:19 AM   #3
seankane's Avatar
Ok I rotated one pot just slightly ccw and now they all read the same. I usually do it by watching current draw on my meter like shown on the tutorial. I have noticed that sometimes when you back it off to stop the draw you have to go a little more sometimes.
Rockford P8002Hide this!Advertise here!
Rockford Fosgate p8002 help. rhempz01 Car Audio 18 28th February 2018 02:30 AM
Rockford fosgate P8002 goes into protect chipper Car Audio 5 23rd October 2016 05:34 PM
Rockford fosgate punch p8002 channel repair chipper Car Audio 2 15th July 2016 10:19 PM
rOCKFORD P8002 edfirebird68 Car Audio 18 6th January 2016 04:39 AM
NOISE on audio system (Rockford 500a2, Sony xec1000, rockford PA2) stoke Car Audio 6 1st October 2010 11:21 PM
