Need help to id parts for Rockford Prime 300x4
Old 6th December 2018, 04:46 PM   #1
mild2wild is offline mild2wild  Trinidad and Tobago
Default Need help to id parts for Rockford Prime 300x4
Was not able to answer this question using existing threads... Need to id Q1 transistor and P1 resistor.
Have here a Rockford Fosgate Prime 300x4 that has a blown film capacitor, an exploded transistor, a burnt resistor and an output that reads low but not shorted.
1) The blown transistor, Q1, is right next to the TL494 IC and has its middle leg directly connected to pin13 of the TL494.
2) The burnt resistor, P1?, is right next to it and each end is directly connected to each outer leg of Q1.
It reads almost 2K ohms when measured UT I can't make out the bands.
The blown capacitor, PC3, is identified as a 10uf25v film capacitor since its case was bouncing around inside, and the B688 of channel 3 reads low when metered. I am hoping that is all that is needed but I am unable to power it up until I change that transistor, resistor, capacitor, and output.
Old 6th December 2018, 05:49 PM   #2
Perry Babin is offline Perry Babin  United States
Do these help?
Old 6th December 2018, 06:00 PM   #3
Thanks for the pics, they are of immense help.
Is it imperative that Q1 be a B772, or can a more readily available substitute be used? If so, what can be substituted that is more common?
Also, can a 10uf50v be used in place of the 10uf25v?
Old 6th December 2018, 09:44 PM   #4
I think the transistor is a switch and not critical but the replacement should have equal or greater ratings for voltage and current.
Are you sure that pins 13/14 are connected to the collector of that transistor?
The 50v cap will be OK.
Old 7th December 2018, 05:01 PM   #5
I was mistaken, the collector of Q1 is connected to pin 12 of the TL494.
I was not able to get a B772 transistor locally UT they gave me a A715 as a substitute. It is close to the B772 but not superior. Vcb is 35v instead of 40v, Vce is 35v instead of30v, and lc max is 2.5A instead of 3A. Do I still need to source a better substitute for the B772? The amp is fully functional as all other parts were replaced and it is operating properly.
Old 7th December 2018, 06:14 PM   #6
I don't know how it's being used in the circuit so I can't say whether it will survive.
If it's used for switching on/off, not high frequency square wave, something like the 2N6491 installed reversed, due to the reversed pin configuration, should work.
Need help to id parts for Rockford Prime 300x4Hide this!Advertise here!
Rockford Prime R600x5 Frycztech Car Audio 68 16th November 2018 01:37 PM
Rockford Prime 1200-1D seankane Car Audio 2 1st April 2018 05:48 PM
Rockford prime 500.1d rhempz01 Car Audio 3 24th March 2018 10:50 PM
Rockford Prime 750.1 help. rhempz01 Car Audio 7 9th September 2017 09:53 PM
Rockford prime 1200 theoddguy Car Audio 0 5th August 2015 02:59 PM
