blowing output transistor DD Z2
Old 7th December 2018, 12:34 AM   #31
Perry Babin is offline Perry Babin  United States
This is what I mean. The yellow is the rail voltage. It comes up first, then the rail-rail oscillation begins. I think there may be an issue (on some 21844 amps) if the oscillation starts as the rail voltage is coming up. The delay allows all of the supplies to stabilize before the driver IC is enabled.
http://www.bcae1.com/temp/ampstartup01.mkv
Old 7th December 2018, 06:33 PM   #32
yoppi is offline yoppi
I have performed the test that indicates me. the result on all 4 sides (4 irs21844) is identical.
File Type: mp4 WhatsApp Video 2018-12-07 at 19.30.41.mp4 (649.5 KB, 10 views)
Old 7th December 2018, 07:41 PM   #33
I'm not sure what I'm seeing in your video. I don't think that the rail-rail oscillation should not start until the rail voltage is steady (I could be wrong. I've never really checked this).
The rail-rail oscillation should not go beyond the rail if you took the signal from the input to the output filter inductor.
The r-r oscillation should also be centered between the rails and not have DC.
Old 10th December 2018, 08:06 PM   #34
Tom7227 is offline Tom7227  United States
Tom7227's Avatar
blowing output transistor DD Z2 Send a message via AIM to Tom7227
Perry ,
Do you know where or how the delay circuit operates? Is the delay circuit on the driver card ?
Old 10th December 2018, 08:47 PM   #35
In the end I mounted a brand new drive board. I will continue doing tests.
I have another digital designs with the same problem.
Old 10th December 2018, 08:49 PM   #36
#34:
I don't repair the 21844 amps often so I've never really had to look at this circuit. The attached is a generic circuit from a 2-21844 amp.
It appears that the Q30 is switched on by Q24 when B+ is applied. When remote is applied, the PNP (Q24) switches off an allows CE39 to discharge through R154. When the capacitor voltage drops below the threshold voltage of Q30, Q30 releases the SD lines, allowing them to pull up and enable the 21844 driver ICs.
Start a new thread or email me if you have more questions regarding this.
blowing output transistor DD Z2Hide this!Advertise here!
Can bias transistor mount on top(body) of output transistor?? Leolabs Solid State 26 28th April 2016 11:34 PM
One driver transistor per output transistor possibilities? rhythmsandy Solid State 25 27th October 2014 12:11 PM
Blowing output transformer pazo Tubes / Valves 3 24th April 2009 03:24 PM
Memphis 1000D Transistor Blowing jf8620 Car Audio 46 12th March 2006 11:49 PM
Leach amp blowing NPN output transistor! supernet Solid State 3 29th June 2002 12:54 PM
