Rockford low power
Rockford low power
Old 9th November 2018, 09:06 PM   #31
imraneesa is offline imraneesa
Originally Posted by Perry Babin View Post
The 20v side of that resistor should connect to the collector of Q10. Find the break between them.
pin 7 of lm393 is 0.7 and so pin1 is pulling low so there is no voltage on base of Q10.
i dont know how pin 7 was showing 4.6v before and pin 1 was 20. that may be for some intermittently showed correct. now actually lm393 pin7 is 0.7v and pin 6 is 4.6v.
Old 9th November 2018, 09:08 PM   #32
Perry Babin is offline Perry Babin  United States
One thing at a time. Why doesn't the collector of Q10 have 20v?
See attached.
Old 9th November 2018, 09:14 PM   #33
See attached.
yes the collector of Q10 is having 20v.
Old 9th November 2018, 09:19 PM   #34
Earlier, it was 0v. What happened? This has nothing to do with the voltage on the 339.
Old 9th November 2018, 09:25 PM   #35
collector is connected to 20v straight that is what i mentioned when i posted voltages for Q10. pin2 is the top pin among three pins i assumed. so collector was pin 2.
i should have mentioned base collector and emitter instead pin1 pin 2 and pin3 which confused. sorry for that it was my fault.
Old 9th November 2018, 09:26 PM   #36
Th collector is pin 3.
OK. Re-post the voltage on the 339 if the voltage has changed.
Old 9th November 2018, 09:33 PM   #37
Thank you for the schematic diagram sir. C5 was bad as soon as i changed it Bias start to work and i am getting super power. that was really strange problem and without you i would have take days to find that. Thank you very much.
Old 9th November 2018, 09:57 PM   #38
I'm sorry that we went around the scenic route but the clean audio on the output had me chasing signal level issues instead of muting problems. Generally, there is absolutely no audio before the bias for the differential amplifiers is enabled.
Rockford low powerHide this!Advertise here!
Rockford Power 851X seankane Car Audio 11 6th March 2018 01:44 AM
Rockford Power 500.2 shawnk Car Audio 2 18th April 2012 07:47 PM
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Help with Rockford Fosgate Power 650 shawnk Car Audio 31 14th July 2010 09:11 PM
Rockford Power 500.2 Amp Troubleshooting power supply. kds9591 Car Audio 6 3rd September 2008 04:09 AM
