Rockford low power
Rockford low power
Old 9th November 2018, 07:21 PM   #21
imraneesa is offline imraneesa
Originally Posted by Perry Babin View Post
So, is the maximum output from both channels 3v AC?
yes both channels have only maximum 2.8v~3v ac on outputs.
Old 9th November 2018, 07:26 PM   #22
Perry Babin is offline Perry Babin  United States
That's very strange that it's clean but low.
What is the DC voltage measured directly across R206 and R306?
Do you see essentially no signal on either side of C301 and C204?
Old 9th November 2018, 07:40 PM   #23
There is no voltage across R206 and R306.
C301 and C204 has slight signal on negative side.
Old 9th November 2018, 07:46 PM   #24
I've never seen clean audio pass with no bias for the differential amp. Do the bias pots do anything?
If not, post the DC voltage on all terminals of the LM339.
Old 9th November 2018, 08:01 PM   #25
There is nothing happening when bias pot is turned. here are the voltages;
Pin1 20.1v
Pin2 4.6v
Pin3 11.7v
Pin4 0.3v
Pin5 2v
Pin6 4.9v
Pin7 4.9v
Pin8 3.9v
Pin9 4.9v
Pin10 4.9v
Pin11 7.3v
Pin12 0v
Pin13 4.6v
Pin14 4.6v
Old 9th November 2018, 08:12 PM   #26
DC voltage on all 3 legs of Q10 and Q11?
Set the bias pots fully CCW so the bias won't be too high when the bias is restored to the differential amplifier.
Old 9th November 2018, 08:25 PM   #27
Q10
pin1 0v
pin 2 20v
pin3 0v
Q11
Pin1 0v
Pin2 -20.2v
pin3 0v
Old 9th November 2018, 08:30 PM   #28
It looks like Q10 has bad connections and may be defective. The collector should be at about 15v. The base is at 20. That should make the emitter about 1/2v below the base.
Old 9th November 2018, 08:48 PM   #29
lm339 pin1 was 20v now i am not getting 20v on pin1 again. R37 has 20v on one side other side is 0v.
Old 9th November 2018, 08:51 PM   #30
The 20v side of that resistor should connect to the collector of Q10. Find the break between them.
Rockford low powerHide this!Advertise here!
Rockford Power 851X seankane Car Audio 11 6th March 2018 01:44 AM
Rockford Power 500.2 shawnk Car Audio 2 18th April 2012 07:47 PM
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Help with Rockford Fosgate Power 650 shawnk Car Audio 31 14th July 2010 09:11 PM
Rockford Power 500.2 Amp Troubleshooting power supply. kds9591 Car Audio 6 3rd September 2008 04:09 AM
