So a cxa1200.1 looks new but close inspection it appears to have had b+ touch ground. I read a short between b+ and ground. What would be the most likely cause in these amps? A shorted ps mosfets or the reverse polarity diode? If power is applied it draws alot of current when only b+ and ground are applied.
