Kicker zx1000.1 input board help
Old 4th November 2018, 04:40 PM   #31
PapaZBill is offline PapaZBill  United States
PapaZBill's Avatar
This is part of the protection circuit. Check the test points in the attached photo.
Any sufficiently advanced technology is indistinguishable from magic.
Arthur C. Clarke
Old 4th November 2018, 06:01 PM   #32
rhempz01 is offline rhempz01  United States
Ok so when I test for the 5v at the ic on pin 4 it causes a audible sound to emmit from the power terminal area, it reads -8.67vdc then shoots up to 5 and the relay clicks. When I probe pin 6 it's the -8.67vdc
I used the RCA sheild for ground.
Old 4th November 2018, 06:03 PM   #33
Its swings the voltage to 5vdc, It also if I do that draws a around 3amps of current.no shorts in the transistors.
Old 4th November 2018, 08:43 PM   #34
Not sure why this photo never went up for the forum. I connected it to r205 positive, and to the bottom ground and made a jumper for the topside. I'll clean this up later.
Old 8th November 2018, 02:52 PM   #35
PapaZBill's Avatar
Check the resistance between the RCA shield and the Power Ground terminal. You should see near zero ohms. If this is not the case check R70-0 Ω resistor. It's also possible there is a blown trace or an open via connecting the top and bottom side of board.
Arthur C. Clarke
Old 8th November 2018, 06:47 PM   #36
It was open. So it read in the mega ohms range. I replaced the resistor, still no audio. If I test pin 4 now it trips the relay. D7 is still removed from the Amplifier. It only .2vdc on pin 4 and on pin 6, 3.45v
Old 9th November 2018, 02:26 AM   #37
PapaZBill's Avatar
Check the transistors in the yellow boxes with an ohmmeter.
Because the voltages on Pin 4 and Pin 6 are low, it possible that there is a shorted transistor, or the IC has failed.
Be sure to check the DC voltages on the header socket for the Class D daughter board.
Arthur C. Clarke
Old 11th November 2018, 07:17 PM   #38
The +-15volts header socket is present. There is full rail voltage on Q101,Q111 transistors. +-86.1vdc. they test good.
Old 12th November 2018, 07:55 PM   #39
PapaZBill's Avatar
Do you have 5 volts on the header socket with and without the Class D board?
Arthur C. Clarke
Old 12th November 2018, 10:36 PM   #40
Yes 5.144vdc
Kicker zx1000.1 input board helpHide this!Advertise here!
Kicker ZX1000.1 repair binupogi Car Audio 3 15th November 2014 12:30 AM
Kicker ZX1000.1 repair djQUAN Car Audio 99 16th August 2012 09:50 AM
Kicker ZX1000.1 No Sound! Need some help please. oldguyoklahoma Car Audio 24 9th April 2012 09:56 AM
Kicker zx1000.1 brandes.cm Car Audio 1 31st March 2012 11:58 PM
kicker zx1000 timwebb Car Audio 0 19th July 2011 02:53 AM
