Kicker zx2500.1 power issues
Old 1st November 2018, 04:30 AM   #61
rhempz01 is offline rhempz01  United States
Removing the thought to be good driver card brought the amplifier out of protection and no outputs heated up on that side. So seems that something on the pulled driver card was triggering the protection curcuit. I'll dig into the card or just replace the c1027/A1023 transistors. Or maybe it's one of the A1381/C3503
Old 1st November 2018, 07:39 PM   #62
PapaZBill is offline PapaZBill  United States
PapaZBill's Avatar
Originally Posted by rhempz01 View Post
Driverboard
Looking at this driver board more closely, I see some damage I overlooked before.I will dig up a board and post a pic for side by side comparison. U1 looks like it may need replacing, and the sm cap above the 470 sm resistor doesn't appear to be attached. This is something you may have addressed. If so ignore my comments.I will upload a pic of a board when I dig one up, for side by side comparison
Also, below is my post I copied to point out the resistors and inductors that should be checked along with all of the transistors.
If any of the driver transistors short (A1381,C3503,A1023y,C1027y) these resistors may open up, check all resistors in their path(***This are only resistor values only, when I get a chance I will post the locators for them**2.2,4.7,910,270).Also check the 22uh inductors(L1,L2,L3,L7).
Any sufficiently advanced technology is indistinguishable from magic.
Arthur C. Clarke
Old 1st November 2018, 07:45 PM   #63
Perry Babin is offline Perry Babin  United States
If this goes on much longer, it may be time to pull the outputs and short the servo op-amp. That should allow testing everything in the amp up to the outputs.
Old 2nd November 2018, 12:18 AM   #64
It was another diode 1n4742 on that card. Test 1411 amp Powers up with oscillation on the outputs.
Old 2nd November 2018, 01:22 AM   #65
PapaZBill's Avatar
Test 1411?
With both boards in place the amp powers up and there is oscillation on the outputs on both sides, correct?
Arthur C. Clarke
Old 2nd November 2018, 09:29 PM   #66
Yes both sides , it was a bad diode the 1n4742 oscillation and clear audio at the speaker terminal. used new silicone tape and some paste for the thermal. Tidied up a fee other things and should be good once in case. Thanks.
Old 3rd November 2018, 01:45 PM   #67
PapaZBill's Avatar
Awesome, This one is a tough nut to crack!!
Arthur C. Clarke
Old 3rd November 2018, 01:58 PM   #68
Yes it is. But Everytime I go through one with you I learn a ton about each model. Helps me for future repairs on these models. The information you provided is invaluable. Couldnt have done this with out you. Thanks. On to the 1500...
Kicker zx2500.1 power issuesHide this!Advertise here!
Kicker ZX2500.1 Jason Smith 616 Car Audio 5 18th January 2018 08:16 AM
Kicker ZX2500.1 Jason Smith 616 Car Audio 24 22nd May 2017 02:30 AM
Kicker ZX2500 No output Deadly Sones Car Audio 14 27th April 2017 03:28 AM
Kicker ZX2500.1 RJohns777 Car Audio 13 27th July 2014 03:52 AM
Kicker ZX2500.1 Dr Zeus Car Audio 19 27th January 2011 10:41 PM
