Ground Zero Amplifier Repair
Old 17th October 2018, 12:40 PM   #31
Perry Babin is offline Perry Babin  United States
Q112 and the components in that part of the circuit are a 'constant current source' (CCS). In this application, it will determine the deadtime and can cause excessive current draw. They rarely need to be adjusted in amps using the IRFB31N20D FETs.
Old 17th October 2018, 12:47 PM   #32
Cekpi7 is offline Cekpi7
I read something about that in link you posted in first reply.
However high side still gets a bit warm with no input, i used 220ohm resistor in series with 910ohm (dmm reads 1082) is that fine or should i maybe get it a bit lower (i only use one fet per bank)?
Old 17th October 2018, 01:10 PM   #33
I'd install all of the outputs, clamp them down tightly and let it idle for 10-15 minutes. The heatsink should not increase in temperature by any significant amount.
For a similar amp, I have the idle current as 1.3 amps before the class D stage is enabled and 1.7 amps after the class D stage is enabled.
Old 17th October 2018, 01:13 PM   #34
Thanks for your help, looks like i have a lot of things to learn.
Current is same (1.3A when protection light is on) and 1.7A after, i installed all mosfets and it didn't change so i guess it's fine. I'm gonna reinstall everything now.
Ground Zero Amplifier RepairHide this!Advertise here!
Ground Bridge amplifier vs btl amplifier where the powerful one ? mahesakomputer Solid State 23 5th November 2015 09:07 AM
Ground Zero GZPA 1.6500 SPL repair maurosubito Car Audio 2 6th August 2014 02:36 AM
Connecting amplifier chasis to earth ground, but not amplifier ground Fusion916 Solid State 3 5th March 2014 08:49 PM
Ground Zero 24 volt amp repair PQatPIT Car Audio 14 11th December 2008 04:26 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
