Rockford Fosgate T8002 Amp diagnosing help
Old 9th October 2018, 09:02 AM   #11
Perry Babin is offline Perry Babin  United States
See attached. The highlighted piece of metal is where the RCA center conductor will make contact.
Old 9th October 2018, 03:56 PM   #12
joocyj is offline joocyj
it seems like its .5v ac straight from my phone, and from my deck it was .7v. Will double check that when I get home.
Old 10th October 2018, 03:32 AM   #13
So double checked just now. About the same through the phone, .4-.5v. Through the deck read out about 2.0v this time, both left and right rca ins and consistently.
Old 10th October 2018, 11:48 AM   #14
With that input signal and level, what's the AC voltage across the speaker terminals of each channel with the gain at the max position and the crossover set to full range?
Old 11th October 2018, 03:23 AM   #15
just to be clear, am i probing a positive and negative of each channel to get this reading?
Old 11th October 2018, 04:42 PM   #16
Yes
Old 12th October 2018, 02:40 AM   #17
Same results on both left and right input. 0.6v ac with no speaker hooked up. Shows .0 volts with a speaker hooked up.
Old 12th October 2018, 04:09 AM   #18
*outputs
Old 12th October 2018, 10:02 AM   #19
Was that on AC voltage?
Old 13th October 2018, 05:53 AM   #20
Yes. I have a better dmm at work than i do at home, i'll try to remember to grab it an check using it as well.
Rockford Fosgate T8002 Amp diagnosing helpHide this!Advertise here!
Faulty Rockford Fosgate T8002 IsakAlexander Car Audio 7 8th October 2018 06:18 PM
Rockford Fosgate 360.6 Jason Smith 616 Car Audio 1 15th January 2018 03:15 AM
Rockford Fosgate T8002 seankane Car Audio 30 27th August 2016 12:02 AM
Rockford Fosgate 100 Hd S Merlington Car Audio 10 4th February 2015 03:01 AM
Rockford T8002 schematic request comecoquito Car Audio 2 28th August 2011 10:23 PM
