Eton PA 5402
Bought this burned amp. Railcaps are open, the inductor was burned and open. rewound the inductor with same size material from an crossover. Power supply is working. if i put the inductor inside, the power supply drops a few times until my fuse is burning. Seems its a tripple layer board. Should be a design from an old zapco. Maybe someone have diagramm. Also all tip35 and the other seems to be ok.
I used the cables shown on the picture instead of the inductor. if i connect the left upper cable to the right lower solder, the amp turns green and the amplitude of the power supply drops. if i connect the other one, the amp switches to red and the power supply turn off. Nothing heats up at all. I dont now, for what this inductor is there. Maybe power supply, but if i measure the connections to the rail caps or to the audio out, there is high value measured. I have asked Eton for a diagram, but they dont replyed.
It's most likely part of the filter for the secondary rails. When you would it, did you get the terminal windings in the correct locations? In the attached image, you can see how the positive and negative voltages have to go to the correct points on the board.
