I wouldn't use the C945. I don't know if the TO-220 transistors will work. In most amps, there would not be enough space for them. For drivers, the BD139 and BD140 have generally been good subs for power supply drivers. If you don't keep them in stock, you should consider doing so.
Yes it was
I can also get mje182/172 from a friend
https://www.google.com/url?sa=t&rct...MJE171-D.PDF&usg=AOvVaw3lUQqCMYKh4z_2nupQQyeX
