Issues after just swaping a 4ch amplifier
Old 15th August 2018, 03:46 AM   #1
SQBubble is offline SQBubble
Default Issues after just swaping a 4ch amplifier
Everything was working great until i switched my 4ch amplifier and completly forgot to disconnect the power line from the battery and i think i messed up something...not sure the cause though...
now both my 4ch amplifiers make really weird noise and the really weird part is that my sub mute option doesnt work anymore WHEN RCAs ARE CONNECTED TO THE 4CH AMP... my REAR channel's xover gets applied to the SUBWOOFER amp instead of the REAR channel... so i disconnected the amp. and my sub amp pops when i turn off the car....
disconnecting the rca from the subwoofer amplifier made the pop go away ..
i havent trying running the 4ch amp without RCAs to see if its fine yet...
did i blew/shorted the RCAs or something in the headunit??
Old 15th August 2018, 04:01 AM   #2
Perry Babin is offline Perry Babin  United States
Check the shield ground on your head unit.
RCA Shield Repair
Old 15th August 2018, 10:59 PM   #3
cool ill try to check this, i tried the 4ch amplifier today and it actually worked great as long as i dont turn on the engine or even go on contact ignition, if i do go on contact ignition it makes a really weird sound and its even worse when i turn on the engine, but all of these noise goes away when the RCA's are unplugged...
im running my factory rear speakers off the head unit's amplifier right now and its working fine, no noise, no issues...
does that mean its an isolated issue with the head-unit's RCA's preout that are messed up for sure? or could it be something else..
im really curious to understand how could this happen though ?..
Issues after just swaping a 4ch amplifierHide this!Advertise here!
swaping Dac chip tralala Digital Source 3 28th October 2016 05:35 PM
Amplifier Issues.... Do It Yourself Solid State 3 26th June 2012 10:41 PM
Swaping preamp boards on JL amps ItsCustom Car Audio 2 11th January 2009 02:16 AM
amplifier issues andyb21 Class D 2 26th June 2005 04:50 AM
new to speaker swaping...help mickyb Multi-Way 3 8th March 2004 09:49 PM
