Working on An Ampere Audio AA-9.0 TFHE. Same as a Sundown Audio NS-1. Anyone know which pin on the power supply driver board is the turn-on? If anyone has a schematic that would be great. Amp was dropped in shipment. When you power it up the relay clicks but power supply does not run. The driver board has ground and 14V going to it but I don't know which pin turns it on.
