Soundstream Rubicon 2500.1 part identification
Old 5th September 2018, 10:58 AM   #61
Perry Babin is offline Perry Babin  United States
Does the 1600 work perfectly?
Is the noise on both audible?
What point are you using for your scope ground?
Old 5th September 2018, 12:02 PM   #62
rhempz01 is offline rhempz01  United States
Scope ground.
Yes fully operational. New
Everything is exactly the same all signals. Noisey. Not present in other amplifiers. My new siligent scope comes today. The drivers in this new amp heat up badly right away hot to the touch? I'll check on shop speakers today if audible.
Old 5th September 2018, 12:57 PM   #63
The drivers operate at very high temperatures. In many amps, they actually damage the board. Not having a fan makes it much worse. If the amp is functioning and has been for a while, the temperature is likely perfectly normal (not good, but normal).
Old 5th September 2018, 01:19 PM   #64
ok. Definitly not good. Maybe ill find a way to disappate some of the heat, a spreader of sorts. or an extra fan(s)
What about the output transistors heating up like that? Is is just beause ii dont have them clamped?
All the signals and voltages look the same as the rub1600.1? I ordered it beacuse i have been so stumped as to why this noise persists despite all my changes.
Not sure what else i can do.
Old 5th September 2018, 01:35 PM   #65
Confirm that the speaker negative is secondary ground and if so, ground your scope to that.
The output transistors with the large drivers and outputs heat up without clamping them. It's possible that you could reduce the idle current by changing the resistor in the constant current source on the driver board but without fine tuning, you may have some distortion in the output.
Adding a fan or adding clip-on heatsinks (with thermal compound) will reduce the driver temperatures. If you do this, replace the MPSA42 drivers and leave the leads long to reduce the heat getting to the driver board.
Soundstream Rubicon 2500.1 part identificationHide this!Advertise here!
rubicon 2500 watt amp cutting off and on charles28 Car Audio 11 18th June 2015 08:16 AM
rubicon 2500 problem any one can help? hadidin Car Audio 7 14th April 2015 07:15 AM
Soundstream Rubicon 2500 brandes.cm Car Audio 1 23rd June 2013 04:37 PM
Soundstream Rubicon 1.2500 in protect bigpun4fubu Car Audio 57 7th August 2012 01:25 AM
Soundstream Rubicon 302 mike49504 Car Audio 20 6th June 2010 03:09 AM
