Again needing help fixing Orion HCCA 225 Digital Reference
Old 7th June 2018, 04:18 PM   #11
Chopperbuilder is offline Chopperbuilder  United States
I had misread your question about it reaching expected output level? I didn't realize you were referring to the sound output... I thought you were referring to it reaching -15v.
Old 7th June 2018, 06:30 PM   #12
Perry Babin is offline Perry Babin  United States
So, without the muting transistors, does the amp work perfectly?
With the muting transistors in (after replacing parts), do the muting transistors reduce the output?
Old 7th June 2018, 06:51 PM   #13
Yes, without the muting transistors the amp works perfectly.
With the new transistors in it does not. The new transistors do reduce the output.
Old 7th June 2018, 06:53 PM   #14
Remove the cap that you replaced near the transformer. Does anything change?
Did you pull one leg of the 221k resistor to check it?
Old 7th June 2018, 08:52 PM   #15
Nothing changed with the cap removed.
I pulled on leg on the 221k resistor and it reads 225k.
Old 8th June 2018, 12:25 AM   #16
What's the positive and negative rail voltage in the amp?
Positive and negative regulated voltage on the op-amps?
Old 8th June 2018, 01:49 AM   #17
Now you got me. I don't know what "rail voltage" is or how exactly to test it.
Don't know how(where on the amp) to test the positive and negative voltage on the op-amps either...???
Old 8th June 2018, 04:33 AM   #18
avtech23 is offline avtech23  Australia
Certifiably addicted to DIY.
avtech23's Avatar
Has this blown resistor been dealt with already?
The ever growing project list.. :NAP140 Clone, NAD 3020i & 3225PE, JLH1969, TDA2050, Fender 5F2A Princeton, NE5532 Pre, SHPA, B1 Korg. : VSQC Phunk Style, Retro 50W, Filmosound 601. : Apex AX-14, TGM-10, TDA7265, LM4780 (Last in line)...maybe
Old 8th June 2018, 04:52 AM   #19
Yes it has.
Old 8th June 2018, 03:50 PM   #20
Okay Perry, I'm doing my best to get up to speed with you(doing my homework).
As to the positive and negative rail voltage - Are these the dual rectifiers in this amp?(see pic). I know how measure positive voltage on them but how do I measure negative voltage?
As to the Positive and negative regulated voltage on the op-amps - I was able to locate one of the caps that supplies power to one of the op-amps. The others I'm unable to follow the traces to figure it out. Will you please point them out for me in the pic? In testing the positive and negative voltage of those caps, I know the square pad is positive and the round negative. To test the negative voltage, I'm I correct in doing so by moving my positive test lead to the negative side?
Also, before I preform the above tests - should I reconnect the components you had me remove in the previous tests(muting transistors and cap) or leave them out?
Again needing help fixing Orion HCCA 225 Digital ReferenceHide this!Advertise here!
Help fixing Orion HCCA 225 Digital Reference Chopperbuilder Car Audio 9 18th May 2018 09:30 PM
Orion 250 HCCA Digital Reference Gioba Car Audio 4 15th October 2013 01:13 PM
orion 225 hcca digital reference problem!? frogq Car Audio 9 21st May 2011 03:51 PM
Orion HCCA 225 Digital Reference with Low Output 0ldSch00lf00l Car Audio 7 4th February 2011 04:32 AM
Orion 225 Hcca digital reference Bunn Swap Meet 0 30th January 2009 12:25 PM
Copyright ©1999-2019 diyAudio
