Again needing help fixing Orion HCCA 225 Digital Reference
Old 18th June 2018, 04:37 AM   #101
Chopperbuilder is offline Chopperbuilder  United States
I just bypassed as much of the trace as possible (see pic) and the voltage remains at -2.5v. I'm thinking we have something else causing the problem.
Old 18th June 2018, 07:37 AM   #102
Perry Babin is offline Perry Babin  United States
That's not bypassing. It's running in parallel. To bypass, you'd have to lift terminal 5 of the opto-coupler. Lift the two resistor legs and run a wire from terminal 5 to those resistors with no connection to the board.
Old 18th June 2018, 07:46 AM   #103
How is it not bypassing when the trace has been cut? As marked by the two arrows. That whole section of trace has been eliminated from the circuit.
Old 18th June 2018, 07:55 AM   #104
You had good voltage with the opto disabled. The opto-coupler simply drives the votlage through that trace. So the voltage is being dragged up by something.
Don't connect at the point where the 1M resistor and cap are. Go from pin 5 directly to the resistors.
Old 18th June 2018, 07:05 PM   #105
Are you are meaning to disconnect the jumper wire from here(see pic)?
I did that and voltage is reading -5.0v
Old 18th June 2018, 09:56 PM   #106
If you remove the jumper, do you get -15v on pin 5 of the opto-coupler?
Do you have pin 3 of the muting transistors in the square solder pad?
With no jumper, what id the DC voltage on the following:
1M resistor and capacitor?
Square pad of the muting transistors?
Old 18th June 2018, 11:50 PM   #107
With jumper removed I'm getting -5.5v on pin 5 of the opto-coupler.
All 3 of the muting transistor are still out of the board.
Can you attach a pic showing me the location of the 1M resistor and capacitor?
Voltage reading on the square pad of the front two muting transistor is 0.0v. Voltage on the one by the transformer is -5.5v.
Old 19th June 2018, 12:33 AM   #108
What is the DC voltage on pin 4 of the opto-coupler?
Is the 270 ohm resistor back in the circuit to enable the opto-coupler?
Yellow arrows, cap and resistor. Green arrow, the solder joints where you connected the jumper at the midpoint.
Old 19th June 2018, 03:19 AM   #109
DC voltage on the 1M resistor and capacitor is 0.0v
DC voltage on pin 4 of the opto-coupler is -5.5v (Pin 5 was -6.5v).
Yes, the 270 ohm resistor is back in the circuit and enabling the the opto-coupler.
Old 19th June 2018, 03:22 AM   #110
lift the 270 ohm resistor again to see if you get -15 on pin 4 of the opto-coupler.
Again needing help fixing Orion HCCA 225 Digital ReferenceHide this!Advertise here!
Help fixing Orion HCCA 225 Digital Reference Chopperbuilder Car Audio 9 18th May 2018 09:30 PM
Orion 250 HCCA Digital Reference Gioba Car Audio 4 15th October 2013 01:13 PM
orion 225 hcca digital reference problem!? frogq Car Audio 9 21st May 2011 03:51 PM
Orion HCCA 225 Digital Reference with Low Output 0ldSch00lf00l Car Audio 7 4th February 2011 04:32 AM
Orion 225 Hcca digital reference Bunn Swap Meet 0 30th January 2009 12:25 PM
Copyright ©1999-2019 diyAudio
