Have you looked at the circuit connections vs the pin configuration of the MIC drivers?
If no one can give a definitive answer, you may have to drive a signal into the amp while looking at the input and output signals simultaneously to see if it's inverting or non-inverting.
Just working on another Z2b.
Power supply is working normal +/- 195V railvoltage
In the class d power section mosfets were blown, these all are off the board.
After switch on , green LED is on, no protection. But...no oscillation on the gates visible, just noise and the railvoltages.
Idle current is 5A-6A, seems normal.
Any ideas..?
Any ideas..?
- General Interest
- Car Audio
- Digital Designs Z2b driver
