The 2 components you found are BJT transistors, they are not mosfets.
Probably the drivers of the malfunctioning channel will also be burned.
Uninstall them and check for short junctions.
WARNING! it may not be the only problem.
Try taking a close-up photo of the channel area that does not work.
